DEXON Systems deploy industry’s first DIMAX4K Intelligent Matrix Switcher Family offering 4K input and output signal handling with seamless switching and quality scaling. The matrices can be integrated using 16x16, 32x32 or 64x64 frames and 4-port input and output boards. All industry standard I/O signal formats and resolutions up to 4K are supported. World unique services as up or down scaling, real seamless switching, transition switching and PIP display make the product basic element for demanding AV installation projects. Easy installation, platform independent remote control and crystal clear video quality guarantee total customer satisfaction.
Professional scaling and format conversion make the product an essential part of AV projects where different signals must be processed, switched and presented. Advanced signal processing provide the highest quality and crystal clear video picture without loss of frames. Seamless switching, transition effects, up- or down-scaling and PIP visulisation services make the product unique on the market. Easy-to-use set up and control can be accessed through push buttons, by local connected keyboard, mouse and monitor or remotely via LAN connection.
The largest Dimax 4K
Dexon will also show off its new New DIVIP4K Video Processor for processing and rendering industry standard signal inputs as video, RGB, DVI, HDMI with HDCP up to 4K, SDI, HD-SDI, 3GSDI, HbaseT compatible direct Cat6 or direct optical fibre. The DIVIP4K can drive several video walls and render the input videos in any size, any position. They offer seamless switch, transition effect and multiple, real time live videos on any output channels with min. 640x480 max. 4K resolutions. Professional video quality and platform independent remote control provide perfect and complete solution for demanding AV projects from 16x16 up to 64x64 size.
Dexon also offers Edge blending and other video wall processors.
