ISE 2017: CreateLED Airs small pitch LED displays
  • ISE 2017: CreateLED Airs small pitch LED displays
    CreateLED launches the AirTV advanced fine pixel pitch LED display at ISE
    2017.
    Press Release
    Amsterdam, Netherlands, 30th January 2017 CreateLED will be exhibiting at the upcoming Integrated
    System Europe (ISE) 2017 show, held from the 7th to the 10th February 2017 at the world famous RAI
    Exhibition Centre in Amsterdam. The ISE show is now one of the largest international shows in the audio
    visual marketplace with more than 1100 exhibitors. The show, which is now in its 14th year, is expected to
    draw over 65 000 visitors, making it the ideal platform for CreateLED to launch their new product offering.
    This year, CreateLED is exhibiting in Hall 8, Stand no. N248 and is proud to be launching 4 new products,
    The AirTV, AirMAG-S, AirMAGLITE-R and ChromaLED PRO HD.
    Introducing AirTV
    As pioneers in the fine pixel pitch LED display market, CreateLED is now launching their latest fine pixel
    pitch offering, aptly named AirTV. The AirTV range will bolster the already well established AirMAG range
    and take fine pixel pitch LED display technology to a new level. Available in 0.9mm, 1.2mm and 1.6mm
    pixel pitch.
    AirTV Back View AirTV Front View
    AirMAG| AirULTRA | AirMAGLITE AirWAVE | AirMAGICBOX | AirBLADE | AirFLOOR AirSPORT | AirMEDIA | AirTOTEM
    Creative Media
    | AirBANNER
    Headquarters
    F1 – F2 Taijiale Industry Area
    Tongguan Road
    High Tech Industrial Park
    Guangming New District
    Shenzhen, P, R, China
    Email: info@createled.com Web: www.createled.com
    Introducing AirMAG-S
    The AirMAG-S has been added to our high definition range to compliment the already well-established
    AirMAG range. AirMAG-S has been designed with weight and thickness in mind, resulting in an ultra-slim
    and ultra-light high definition indoor LED display solution. The space saving AirMAG-S boasts advanced
    side entry cable management system saving valuable space behind the display. AirMAG-S starts at a pixel
    pitch of 1.6mm upwards.
    AirMAG-S Back View AirMAG-S Front View
    Introducing AirMAGLITE-R
    CreateLED’s latest offering for the live events and touring industry is called the AirMAGLITE-R. Like the
    new AirMAG-S, it has been designed with weight and thickness in mind, providing the rental industry with
    an advanced high definition outdoor LED display solution. The AirMAGLITE-R comes with handy
    accessories like touring frames, transport dollies and fly kits, making it very quick and convenient to set up
    and dismantle. Available from a pixel pitch of 3.9mm upwards.
    Creative Media
    | AirBANNER
    Headquarters
    Tongguan Road
    AirMAGLITE-R Back View AirMAGLITE-R Front View
    Introducing ChromaLED
    ChromaLED PRO HD is an advanced LED display controller by CreateLED. The ChromaLED PRO HD is
    able to accept DVI, HDMI, SDI, and DP and can output an amazing resolution of 3280 x 2048 pixels per
    unit. This advanced LED display controller enhances gray scale, contrast ratio, sharpness and refresh rate,
    making it the ideal match to any CreateLED display product.
    CreateLED is a global technology company specializing in the design and manufacture of high performance
    LED displays for indoor and outdoor use.
    Headquartered in Shenzhen, China, and operating in a global market, CreateLED is one of the nation's
    leading designers and manufacturers of LED screen technology.
    More Information:
    http://www.createled.com
