Hello everyone,
If this post were placed in the wrong section, kindly do accept my apologies.
I'm building a professional racing simulator at home and I don't know which projector is best for my application (180-200 deg cylindrical projection screen using 3 projectors).
The closest context to mine is done through a simulation company called Cruden, and they use Barco projectors (F70-4K6, phosphor laser @ 5000 lumens). My conundrum is that I do not know which system provides the lowest input lag.
I contacted Barco in order to enlighten my regarding their product's latencies, and here's their reply:
"Thanks to advanced Barco Pulse electronics platform, which these models are based on, their introduced latency is the lowest on the market. Exact values are dependent on several factors - frame rate, resolution, complexity of applied geometry correction, synchronization settings, etc. For WQXGA(2560x1600)@120Hz operation mode you may expect transportation delay of about 1.0-1.5 frames (9-13 ms).".
I'm not sure if this 'Barco Pulse electronics platform' is the real deal or just a fancy term for a generic technology. I barely know how to understand which projector is better. Also, in my research, I read that a 3-chip projection mechanism is better that 1, which makes the Barco at a disadvantage - as expensive as it is.
My requirements are as follows:
Lowest possible input lag @ 2560x1600 (most important requirement)
Minimum frequency of 120hz @ 2560x1600 or lower resolution (if it can support 4k@120hz = even better)
Minimum brightness of 3000 lumens
HDR Support (preferably)
Laser phosphor
Warp and blend technology
room dimension: 7x6 meters
To give you a perspective on what I'm trying to build, its something like this:
dailysportscar.com/wp-content/uploads/2016/05/Base-Performance-01-730x487.jpg
Thank you for your help in advance!
Laser phosphor
