French high-end switcher and signal processing manufacturer Analog Way is launching what it labels as 'the Ultimate Video Processing Toolbox',
VIO 4K at ISE 2016.
VIO 4K is a powerful multi-format converter offering the latest generation of digital connectivity, adapted to the highest resolution formats. Natively equipped with 7 inputs, VIO 4K enables the conversion of a multitude of signals including: Dual-Link DVI, DisplayPort 1.2, HDMI, 6G-SDI, Optical, and universal analog, into an impressive array of output signal formats up to 4K 30Hz 4:4:4. Thanks to perfect symmetry between input and output plugs (anything in, anything out), VIO 4K ensures high-end cross-conversion.
The VIO 4K is a new powerful multi-format converter offering the latest generation of digital connectivity. However the base unit is limited to 30 frames per second in 4K, fortunately it has two expansion slots for additional processing boards. Adding one of the optional boards, the unit supports formats 4K 60p 4:4:4 . The first scheduled optional board includes HDMI 2.0 + DP 1.2 input and output plugs. Bitdepth at this resolution is 4:4:4 upto 10 bits depending on the chosen input/output plug. According to Analog Way 12 bits is interesting for HDR, but this topic is not yet standardized enough: each manufacturer has its own solution.
Analog Way is working on a single cable SDI solution for 4K 60P to complement its standard 6G SDI connectivity. "our roadmap includes a 12G-SDI option with conversion capabilities to/from quad 3G-SDI".
Asked why not include the latest version of Displayport, it turns out that 1.2 does offer sufficient capacity for 4K: "DP1.2 is enough for 4K 60p 4:4:4. For our market, Display port 1.3 is interesting if you want to support 8K60p 4:2:0", according to company spokesperson Marion van de Graaf.
For a better audio experience, VIO 4K offers advanced management of digital and analog audio signals. VIO 4K was designed and built to provide optimum versatility. It includes two slots for optional cards for video processing that can handle formats up to 4K 60Hz 4:4:4, and another slot for optional audio card with XLR plugs. With all options, VIO 4K features 9 inputs and 3 outputs. Any card added is independent and has its own processing. For easier product maintenance and reliability, DVI plugs are located on simple, independent cards.
Perfectly adapted for non-standard signal management, notably for LED walls, VIO 4K offers unique features and functionalities. The Dual/Tri output mode enables association of a single source to three outputs and to independently modify formats, aspect ratio, the Area Of Interest (AOI), etc. The rotation feature allows output rotation for portrait vs landscape displays at 0°, 90°, 180° and 270° per output. The advanced management of the AOI as well as unlimited layer resizing capabilities allows precise sizing of a source to fit odd resolution displays.
VIO 4K can be controlled easily directly from the front panel, thanks to a large 3.5? TFT color screen offering live visualization of sources. A Web Server is also available to control VIO 4K through Ethernet and USB plugs. This solution offers a complete intuitive graphic interface. Using either the front panel or the software, operators can visualize live sources to further assist in basic operations.
The Vio 4K is a smaller platform than the large Ascender switcher platform, the smallest 16 version was launched at ISE 2015. It has a smaller base configuration, but the same chassis as the big switcher/processors, so with additional processorboards it is upgradable to the largest capacity processor.
Analog Way is a leading designer and manufacturer of presentation switchers and image converters. The company designs a wide range of computer to video scan converters, scalers, seamless switchers and up/down converters. Analog Way's target market is rental & staging, but also includes broadcast facilities, and for instance its Diventix unit was long used in high-end CRT soft-edge blends.
VIO 4K at ISE 2016.
