Aavara will be showcasing its latest 4K/HDMI Over IP solution at ISE 2016, featuring up to 4K HDMI video, Multi-channel Audio, High Speed USB and IR/RS-232 control signal broadcasting to multiple TVs/Displays/Projectors over IP network. By fully leveraging the mature inexpensive Cat5e/6 cable, Fiber Optical and Gigabit Ethernet network switches, it distributes stunning 4K Ultra HD or 1080p HDMI Video. Support Point to Point, Point to Many Broadcasting, and Many to Many Multi-Casting which multiple video sources streaming to multiple TVs/Displays/Projectors.
In addition, powerful video wall feature can establish and managed video wall up to 9x9 and flexible to change different video wall patterns quickly.
Aavara 4K/HDMI Over IP is a great Ultra HD/HD video distribution solution for DOOH/Signage/Video Wall commercial and residential AV deploy.
Built-in Easy to Use Aavara AV Master Web Interface that user can centralize control entire Over IP AV network to do multicasting, and videowall easy and intuition.
- Built-in on every box without extra cost.
- One central control web page to control entire AV IP Matrix system
- Auto Search all senders and receivers among network
- Easy Multicasting/Multicast Grouping/Snapshot/… operation
- Easy and Flexible VideoWall setup and operation up to 9x9
3rd party Controller Integration Support
3rd party Controller driver likes Control4, Crestron, AMX, RTI and Elang g! Support full
functions controlling including multicasting, videowall, rs232 IP commands, …, directly
from 3rd party controller to Aavara boxes for Residential and Commercial projects
integration.
PB9000 4K over Gigabit Network
- 4K Over 1 Gigabit Network with Ultra low 16~33ms latency
- Up to HDMI 2.0 4K 2160p60Hz 4:2:0 Video Input
- Up to 7.1 ch Audio or more (LPCM/DTS/Dolby/Dolby ATMOS)
- USB 2.0 pass-thru for IP KVM application
- 4K VideoWall (also can support 4K in 1080p out video wall)
- Hybrid Video output(Each Receiver can choose different video format independently)
- Video Rotation/Mirror/Stretch for commercial installation and video wall
- HDMI Audio Extract to Analog audio output (2 channel LPCM audio only)
- Max. Bit Rate control (10 Mbps ~ 800 Mbps)
- Video Snap shot (Video Capture)
- HDCP 2.2 support (for 4K Blu-Ray & Video Streaming)
- Built-in SFP Fiber Optic connection for KMs point to point connection
- Built-in PoE support
For detailed spec and features: http://www.aavara.com/en/products/hdmi.php?id=39
integration.
