Digital Projection will release the second generation of its HIGHlite Laser Hybrid Laser-Phosphor Projector at ISE 2016.
The HIGHlite Laser II ships mid Q2 2016, and brightness is bumped to 13K lumens.
The HIGHlite Laser II brings a range of impressive improvements to the already popular HIGHlite Laser model. While maintaining its unbeatable 20000 hours of illumination, the second-generation product now boasts an impressive 13,000 ANSI Lumens of brightness. Other key features include the introduction of all-new electronics that offer improved video processing and a full 120Hz processing path from DisplayPort Sequential 120Hz or 60Hz per input Dual-pipe HDMI.
Combine the exceptionally bright, long-life illumination source with a host of other precision features, and you have a projection solution that’s perfectly suited to a diverse range of professional venues. Image Edge Blending is included as standard, along with advanced geometric correction. HDBaseT, DisplayPort 1.2 and HDMI ensure that the connectivity is comprehensively future-proofed.
Equally compelling is the lack of lamp replacement due to the solid-state illumination system. By eliminating regular lamp replacement cycles, almost all costs related to the HIGHlite Laser are limited to the initial hardware purchase. This key characteristic affords the HIGHlite Laser II an extremely low cost of
ownership over the lifespan of the display. Venues looking to produce a compelling visual experience will realise true cost-saving benefits through the HIGHlite Laser’s advanced illumination technology.
