The projector is build around a new D-ILA, as JVC brands its LCoS imager chips, chip. It is the smallest native 4K "D-ILA" device, yet. As JVC has been selling 4K/8K projectors with older larger 4K D-ILA chips. It is paired with together with a Laser light source "Blu-Escent".
The JVC DLA-Z1, a new Home Theatre Projector using JVC original developed native 4K D-ILA device, which will be available in Europe from late November. This new projector includes a Laser light source “Blu-Escent”, realising a brightness of 3,000lm which also has dynamic light source control, unique for laser, plus 20,000 hours operational life time. Additionally a high brightness, high quality, and vivid 4K picture can be produced thanks to the new lens dedicated for 4K and the new Cinema Filter with wide color gamut.
The new D-ILA chip is an 0.69inch device. By using both vertical orientation technology and planarization technique, unnecessary scattering and diffraction of light has been decreased to realise high contrast ratio.
JVC claims high brightness of 3,000lm and 20,000 hours long life can coexist, because the light source will be JVC original Laser technology “Blu-Escent” using a Blue Laser diode.
JVC claims to have made laser control work providing infinite contrast: "Using the Laser Diode as the light source, light output can be controlled instantly. This means brightness control can be made without delays compared to the conventional mechanical adjustment (lens aperture). DLA-Z1 can control the laser output accordingly to the scene’s brightness, which creates picture that is close to the human perception. Also by controlling the laser output when switching scenes or during signal identifications, contrast ratio of ∞:1 has been realised".
A new Cinema Filter can obtain wide colour gamut of 100% DCI P3 and over 80% coverage of BT.2020. The gradation of sky or sea, the crimson red of a rose, the fresh green of trees can be reproduced vividly like never before. It can realise a beautiful picture even when compared to movie theatres for UHD Blu-ray contents, by expressing the various colours contained in the content utilising the wide colour gamut.
JVC is known for using quality lenses on its HT projectors sounds like this new generation is no exception: "a new 16 group 18 sheets all glass lens and full aluminum lens barrel has been developed. The diameter of the lens is 100mm compared to conventional 65mm, in order to project the 4K resolution to every corner of the screen whilst keeping a wide shift range of 100% vertical, 43% horizontal shift.2 In addition, adopting five anomalous dispersion lenses in accordance to the different refractive index of R/G/B light, the chromatic aberration and color fringing when shifted can be minimised, resulting in precise projection of 4K resolution graphics".
The DLA-Z1, having high contrast ratio with 80% BT.2020 coverage, and dynamic light source control together with high brightness, can let you enjoy the full merit of HDR images
