Resolution/Aspect Ratio Cheat Sheet v1.6
  • Resolution/Aspect Ratio Cheat Sheet v1.6
    Below is a cheat sheet for the resolution to use when exporting for various aspect ratios and frame sizes. Commonly used formats and sizes are highlighted in green.
    If you spot any faults or have any suggestions for updated versions, shoot me an email : ) brad @ unravel . com . au
    Brad Allen
    Note: Many people refer to 2.35:1, 2.39:1 and 2.40:1 but these days they are usually all actually referencing the 2.39:1 aspect ratio. 2.35:1 was used in films prior to 1970 and 2.40:1 is an incorrect rounding from 2.39:1 to 2.40:1. Having said this, there are times when delivering at 2.40:1 is actually required rather than 2.39:1 - Bluray's spec for anamorphic/scope content is one example. As a result – all variants are included in this document.
    The end message is that when it comes to anything between 2.35-2.44 I find it's best to just look at what the target destination is and run with what their predefined spec is (i.e. Blu-ray @ 1920x800, 2KDCP @ 2048x858, 4KDCP @ 4096x1716 etc.). It always pays to check what your destination is expecting to receive from you rather than trying to convince them you have it the right way round!
    Cinema DCP 4K Cinema DCP 2K
        Frame Aspect Ratio Resolution (Square Pixels 1.0)
      Flat (1.85:1)
        3996x2160
      Scope (2.39:1)
        4096x1716
    Full Container 4096x2160
      Flat (1.85:1)
        1998x1080
      Scope (2.39:1)
        2048x858
        Full Container 2048x1080
    8K 8K UHD
        1.33:1 (4:3) 8192x6144
        1.66:1 (5:3) 8192x4915
        1.77:1 (16:9) 8192x4608
        1.85:1 8192x4428
      1.90:1 (Dragon VV and 8K Helium Full Frame)
        8192x4320
      2:1
        8192x4096
        2.35:1 8192x3486
        2.37:1 (RED 8K Wide) 8192x3456
        2.39:1 (often called 2.40) 8192x3428
        2.40:1 8192x3413
        2.44:1 8192x3357
          1.33:1 (4:3) 7680x5760
          1.66:1 (5:3) 7680x4608
      1.77:1 (16:9)
          7680x4320
        1.85:1 7680x4151
          1.90:1 7680x4042
      2:1
          7680x3840
        2.35:1 7680x3268
          2.37:1 (64:27) 7680x3240
          2.39:1 (often called 2.40) 2.40:1
    2.44:1
    7680x3213 7680x3200 7680x3148
    6K 5K
        1.33:1 (4:3) 6144x4608
        1.66:1 (5:3) 6144x3686
        1.77:1 (16:9) 6144x3456
        1.85:1 6144x3321
      1.94:1 (Dragon Full Frame)
        6144x3160
      2:1
      6144x3072
        2.35:1 6144x2614
        2.37:1 (RED 6K Wide) 6144x2592
        2.39:1 (often called 2.40) 6144x2571
        2.40:1 6144x2560
        2.44:1 6144x2518
        1.33:1 (4:3) 5120x3840
        1.66:1 (5:3) 5120x3072
        1.77:1 (16:9) 5120x2880
        1.85:1 5120x2768
      1.9:1 (Epic-X Full Frame)
        5120x2700
      2:1
      5120x2560
        2.35:1 5120x2179
      2.37:1 (RED 5K Wide)
        5120x2160
        2.39:1 (often called 2.40) 5120x2142
        2.40:1 5120x2133
        2.44:1 5120x2098
    4K 4K UHD
        1.33:1 (4:3) 3840x2880
        1.66:1 (5:3) 3840x2304
      1.77:1 (16:9)
        3840x2160
        1.85:1 3840x2076
        1.9:1 3840x2021
        2:1 3840x1920
        2.35:1 3840x1634
        2.37:1 (64:27) 3840x1620
        2.39:1 (often called 2.40) 3840x1607
        2.40:1 3840x1600
        2.44:1 3840x1574
        1.33:1 (4:3) 4096x3072
        1.66:1 (5:3) 4096x2458
      1.77:1 (16:9)
        4096x2304
        1.85:1 4096x2214
      1.9:1 (Native 4K RED)
        4096x2160
        2:1 4096x2048
        2.35:1 4096x1743
        2.37:1 (RED Wide) 4096x1728
        2.39:1 (often called 2.40) 4096x1714
        2.40:1 4096x1707
        2.44:1 4096x1679
    3K 3K HD
        1.33:1 (4:3) 3072x2304
        1.66:1 (5:3) 3072x1843
        1.77:1 (16:9) 3072x1728
        1.85:1 3072x1661
        1.9:1 (Native 3k RED) 3072x1620
        2:1 3072x1536
        2.35:1 3072x1307
        2.37:1 (RED Wide) 3072x1296
        2.39:1 (often called 2.40) 3072x1285
        2.40:1 3072x1280
        2.44:1 3072x1259
        1.33:1 (4:3) 2880x2160
        1.66:1 (5:3) 2880x1728
        1.77:1 (16:9) 2880x1620
        1.85:1 2880x1557
        1.9:1 2880x1516
        2:1 2880x1440
        2.35:1 2880x1226
        2.37:1 (64:27) 2880x1215
        2.39:1 (often called 2.40) 2880x1205
        2.40:1 2880x1200
        2.44:1 2880x1180
          2K 1080p
        1.33:1 (4:3) 2048x1536
        1.66:1 (5:3) 2048x1229
        1.77:1 (16:9) 2048x1152
        1.85:1 2048x1107
        2:1 2048x1024
        2.35:1 2048x871
        2.37:1 (64:27) 2048x864
        2048x858
      2.40:1
        2048x853
        2.44:1 2048x839
        1.33:1 (4:3) 1920x1440
        1.66:1 (5:3) 1920x1152
      1.77:1 (16:9)
        1920x1080
        1.85:1 1920x1038
        2:1 1920x960
      2.35:1
        1920x817
        2.37:1 (64:27) 1920x810
    2.40:1 (Blu-ray Scope) 2.44
    1920x803 1920x800 1920x787
    720p
        1.33:1 (4:3) 1280x962
        1.66:1 (5:3) 1280x768
      1.77:1 (16:9)
          1280x720
        1.85:1 1280x692
        2:1 1280x640
        2.35:1 1280x545
        2.37:1 (RED Wide) 1280x540
        2.39:1 (often called 2.40) 1280x536
        2.40:1 1280x533
        2.44 1280x525
    576p (PAL SD)
    Frame Aspect Ratio
            Resolution Resolution (Square Pixels 1.0) (PAL Widescreen 1.46
    Pixel Aspect Ratio)
    Resolution (PAL DV 1.09 Pixel Aspect Ratio)
        4:3 768x576 --
        720x576
        16:9 1024X576
        720x576
    480p (NTSC DV SD)
    486p (NTSC D1 SD)
        Frame Aspect Ratio
            Resolution Resolution (Square Pixels 1.0) (NTSC DV Widescreen
    1.21 Pixel Aspect Ratio)
    Resolution (NTSC DV 0.91 Pixel Aspect Ratio)
        4:3 640x480 --
        720x480
        16:9 854x480
        720x480
        Frame Aspect Ratio
        4:3 648x486 --
        720x480
          16:9 872x486
        720x480
    Pal was analog, so there was a difference between active and total lines, unlike digital standards where they are the same. So its hsould read 525P, like 480P is the NTSC match in digital/streaming formats.
    Secondly 8K UHD(TV) from the start has been 7680 x 4320, I should still have a hand-out from NHK, in the attic, from when it brought the Super Hi-Vision system out to the world, with 'UHDTV being the name for outside Japan', paraphrasing here as it has been 11 years since;-).
