All,
It's been several years since I posted on this forum. Back in the day (4 years ago) I purchased a Digital Projection Inc (DPI) Highlite HL10000K HD projector and all though I only had a chance to view it in my work shop because of the 220v electrical requirement, I never forgot the picture it made. I didn't end up using the DPI because of the 220v, the db level, the size, and the heat. But I've always wanted another 2K projector so in Jun 2018 I pulled the trigger on a used Sanyo PLC-HF10000L 2K, 10000 lumens, LCD projector. Now I know this isn't a DCI or DLP projector but no one is discussing anything related to 2K projectors over in the AVSForum so I thought I would try here for some guidance.
Now if you'll bear with me I will tell you why I'm IN LOVE with this projector
1. I currently have an Epson LS10000 mounted on my ceiling and the Sanyo will replace it as soon as I get back home from Afghanistan.
2. The Sanyo is very light and small for a 2K projector, 60lbs and WxHxD= 20.9”x10.6”x29.8”. I can lift this projector very easily.
3. It's surprisingly quiet for a 2K projector, 39 dBA in eco mode
4. It's 10K lumens with 2 lamp but I've been running it on one and it's very bright on my 120" diagonal acoustic screen.
5. One of the most important things, it's 110v electric.
6. It has very large 1.64" TFT Poly Inorganic LCD panels with QuaDrive.
On the picture quality, this is an LCD projector which can look every bit as good as a 3 Chip DLP 2K projector, the picture has depth, saturation, and a solidness that look like DLP. I think this has allot to do with the size of the LCD panels and the lens quality. The lens is huge with a nice weight. This is a link for the only review I could find
"https://www.audioholics.com/projector-reviews/sanyo-plc-hf10000l-2k"
So now that I have this thing, I need to start learning about the best way to set it up, what signal feed it and how to calibrate it.
Question for anyone willing to help me out?
1. Should I feed this projector 1080p or purchase a video process that can do 2K. I was thinking about one of the Lumagens which would also give me the AutoCal with 3D Luts? I already own a Lumagen XE and I've always enjoyed the AutoCal and 3D Lut capabilities of the Lumagens.
2. I plan to watch Bluray movie and HDTV so should a calibrate for Rec 709 or try for P3, with 4:4:4 deep color. I think this is a 10 bit projector. It has a HDMI 1.3 port with HDCP, a DVI. It also has a SDI which can be purchased.
That's about it for now and sorry for the long post. I've attached the Spec sheet for any interested.
Andre
Andre
