Schubin 'HDR works on everything; 4K and wider color gamut are tough sells'
  • Schubin 'HDR works on everything; 4K and wider color gamut are tough sells'
    Q&A: Mark Schubin on 4K, UHD, HDR and More
    Schubin provides a preview of NAB Super Session discussion
    April 11, 2016
    By Deborah D. McAdams
    LAS VEGAS: There are few set standards for 4K, UHD, high dynamic range, high frame rate or wide color gamut. Each has a particular path from capture to the home through an HDMI cable into a 4KTV set from one of several manufacturers offering a variety of technologies. So how will adoption be achieved?
    That's what four top broadcast engineers take on during the NAB Show in a Tuesday, April 19 at 2:30 p.m. Super Session entitled, "4K, UHD, HDR and More-The Future of Video." TV Technology's Deborah D. McAdams will grill video expert Mark Schubin, SMPTE President and CBS Vice President of Engineering and Advanced Technology Robert Seidel, broadcast veteran Jim DeFilippis and Ericsson's Matt Goldman with crowd-sourced questions from their peers.
    Here, Mark Schubin provides a preview.
    CROWD MEMBER: What provides the best bang for the buck: 2160p resolution, high dynamic, wide color gamut, or high frame rate (120 fps)?
    SCHUBIN: In my opinion, HDR and HFR offer the most bang for the buck. HDR might be easier to implement, but it can increase motion artifacts, bringing us back to HFR.
    C.M.: The Canadians are now doing baseball, basketball and hockey in 4K, and distributing it via cable. What is holding up the U.S. broadcasters?
    SCHUBIN: They're more sensible.
    C.M.: What are their immediate challenges?
    SCHUBIN: Viewers.
    C.M.: What about standards? What's needed?
    SCHUBIN: Agreement (as usual in the case of standards).
    C.M.: Beyond sports, what other genre will benefit and have a business ROI?
    SCHUBIN: HFR is primarily for sports. HDR works on everything; 4K and wider color gamut are tough sells to viewers for anything.
    C.M.: Will broadcasters be "forced" into 4K/UHDTV adoption similar to the evolution of HDTV?
    SCHUBIN: I don't think so. There is a much smaller perceptual improvement from HD to 4K than there was from SD to HD.
    C.M.: What are the key dominos in the chain that need to be knocked over for the consumers to feel this is real and start spending? Is it availability of "great titles," consumer devices, branded premium channels, marketing or something else not yet concocted?
    SCHUBIN: 4K, again, has very limited perceptual grab. Anyone who doubts that should visit Bob's demo at CBS with side-by-side giant screens. Wider color gamut sells only in a side-by-side demo; consumers would have to see it in stores that way, and store shopping is on its way out. HDR and HFR are both perceptually significant.
    Some fear HFR is perceptually significant in the wrong direction for scripted programming. HDR might be easier to implement, but it depends a lot on the home viewing environment. HFR needs agreement on a bit-rate reduction system (compression).
    C.M.: The young adults of today are notorious for consuming social content on small, portable devices. They are the future money for this. Why do they need it?
    SCHUBIN: HFR is significant on any size screen at any viewing distance but primarily for fast-moving content. HDR is going to be tough on a handheld screen outdoors. 4K is largely irrelevant on a handheld screen, and WCG probably won't be noticed. But even young adults are using larger screens for longer programming.
    C.M.: How do we as an industry start our advancement to UHD and HDR?
    SCHUBIN: Standards.
    C.M.: What is the immediate opportunity for a TV group with regard to these technologies?
    SCHUBIN: PR.
    C.M.: Are we now headed toward 1080p60 with HDR and wide color as a first step, with 4K used in production and on-set display etc.?
    SCHUBIN: From your words to the powers that be! Except maybe it'll be just HDR on regular HD, and forget the 4K.
    C.M.: What are your thoughts on HDR HD facilities versus native 4K HDR?
    SCHUBIN: HDR works just fine on HD.
    C.M.: Is the notion of HDR for HD now officially dead?
    SCHUBIN: No one told me!
    C.M.: Given the file sizes, do you think we should be significantly compressing in acquisition and post, just as we did in the early stages of HD?
    SCHUBIN: For 4K, it's probably necessary. For the other improvements, no.
    C.M.: HDCam, while not perfect, was a pragmatic way of getting to HD and getting material out to audiences. What's the equivalent for UHD?
    SCHUBIN: HD.
    C.M.: 4K, 8K, UHD, and HDR require a very large network topology to support file transport...
    SCHUBIN: I don't understand that statement. What does "topology" have to do with anything? And the increased data rate for HDR borders on the insignificant; for the Philips version, it's just 35 bytes per scene (not per frame or per second).
    C.M.: ...how do we justify that investment when the delivery to the home will not support the transport without heavy compression for years to come?
    SCHUBIN: As you can tell from my other answers, I'm not a big fan of a move to 4K, but, if I were, I would point out that, for entropy coding, the sharper the pixels and the less change between pixels, the easier the compression. So raw 4K might be 8x the data rate of HD (1080i or 720p), but the compressed-data-rate increase would be a small fraction of that. Gary Demos showed some compression at the HPA Tech Retreat in February with extraordinary spatial resolution and dynamic range and not a high bitrate.
    C.M.: Will 4K become a standard transmission?
    SCHUBIN: Not on my account
    C.M.: What are your views on affordability of transmission methods for 4K, that is, broadcast, broadband and/or satellite?
    SCHUBIN: See my comments on "heavy compression" above.
    C.M.: Do you think there is benefit to using HDR and/or 4K to author a better HD product that can be delivered to consumers without significant changes to current infrastructure, instead of racing to provide 4K?
    SCHUBIN: In the case of HDR, absolutely. Grass Valley likes to show an image of a combined HDR/SDR sports production in which the SDR video controllers are constantly making adjustments (as usual) and the HDR video controllers were leaning back with their hands behind their heads. In general, the more you can offer post, the better. As for 4K, there have been mixed opinions about extracting an HD image from a portion of the frame. Potentially, increased sensor resolution would improve sharpness even for HD.
    C.M.: Shooting UHD side-by-side with HD is too costly. How can we reduce the cost of producing sports in UHD and HDR?
    SCHUBIN: For 4K, relatively simple downconversion is probably fine. For HDR, many people have been working on some form of algorithmic downconversion; at the moment, human intervention might be necessary (no worse than the job of a video controller).
    C.M.: How can we do live production of HDR sports without needing separate "shaders" for an HDR/wide color gamut output and an SDR/normal color gamut output for legacy TVs?
    SCHUBIN: See answer above. At worst, it would be one "shader" converting the HDR to SDR.
    C.M.: Do you think that high frame rate is suitable for all genres?
    SCHUBIN: Tough question! I think it's great for anything intended to look "live" (sports, news, talk, game shows, concerts, operas, ballets, etc.). For scripted programming, everyone alive today has been watching it largely at 24 or 25 fps, and they are accustomed to that look. Is it just that they are accustomed to it, or is there some psychophysical reason that 24 or 25 fps helps suspend disbelief? I don't yet know.
    C.M.: Given the propensity of advertisers for brighter brights and whiter whites, how do we avoid the CALM Act for brightness?
    SCHUBIN: Those helpful algorithms, again! But there is a real issue associated with long-term exposure to very high light levels: retinal "bleaching." If you're watching skiing for half an hour at high brightness and change channels to a night scene in a noir movie, it might be like driving into a tunnel at noon on a sunny day.
    C.M.: How do we integrate interstitials into programming without brightness and color wars?
    C.M.: How well can we produce for both HD and HDR without serious compromises, particularly in graphics or saturated colors?
    SCHUBIN: Keep the graphics in the SDR subset of HDR, and don't sweat the saturated colors. As George Joblove pointed out at the HPA Tech Retreat, we should be dealing with gray as a reference, not black or white.
    C.M.: Given the constraints of the television, cable and satellite system, how comparable will the broadcast experience be to the ultra Blu-ray?
    SCHUBIN: Could be the same; could even be better.
    C.M.: Given the wide disparity of displays and capabilities on the market, how well can we author once and use everywhere, and how much will the user experience vary?
    SCHUBIN: Never mind the equipment! If the viewer turns lights on or off or opens or closes drapes, the experience changes. But that's always been the case. Viewer experiences today vary greatly; that's why The New Yorker was able to run a cartoon by Joe Dator on Sept. 8 showing a doctor telling a patient that he'd like to see about fixing his aspect ratio. Plenty of viewers are watching stretched people today.
    C.M.: As HDR displays get better and do a nice job of presenting SDR-graded content better than it would look on a legacy UHD display, does this challenge the value of specific HDR grading? What percentage of average consumers will appreciate the difference?"
    SCHUBIN: I haven't yet seen HDR upconversion; I have no idea what it might look like.
    C.M.: When will lower-end 4K cameras offer servo lenses?
    SCHUBIN: Define "lower end." AJA's "RovoCam" 4K camera has a built-in servo lens and costs $2,495 including the lens; is that "lower-end" enough?
