BAKO's Small Pitch LED Display of P1.26, P1.61 and P1.9 are Becoming Popular
  • BAKO's Small Pitch LED Display of P1.26, P1.61 and P1.9 are Becoming Popular
    BAKO's Small Pitch LED Display of P1.26, P1.61 and P1.9 are Becoming Popular on the Market
    SHENZHEN, China, Nov. 10, 2016 /PRNewswire/ -- BAKO, a leading LED display manufacturer in China, introduced its WAVE SERIES and BIRD'S NEST SERIES for indoor small pitch LED display of P1.26, P1.61 and P1.9. With its eye-attractive design and the perfect showing effect, it quickly grasps users' attention on international market.
    At present, WAVE SERIES contains P1.26 and P1.9 while BIRD'S NEST SERIES contains P1.61. Later, there will be some more smaller pitches. BAKO's deign has the following features when compared with other competitors in the market:
    1) The design itself is a high-level artwork. When many cabinets are connected together, WAVE SERIES LED screen looks like a river dotted with little waves while BIRD'S NEST LED screen looks like Chinese National Stadium named Bird's nest.
    2) It can take the place of DLP and LCD directly. BAKO small pitch LED display can make 55'', 110'', 165'' and 70'', 140'', 210'' to replace DLP and LCD. Comparatively, LED display has the advantages of seamless connection, better showing effect and convenient maintenance.
    3) Cabinet width and height ratio is 16:9. For many projects, 16:9 is an important request. In view of this, we make the cabinet ratio 16:9. In this way, even if we make a big size screen, the screen ratio can still be kept.
    4) Good contrast. For some special applications like TV station, contrast is a key factor to take into consideration. BAKO applies black SMD1010 black lamp and has its own design of mask, with the whole display's contrast much improved.
    5) Good gray scale with low brightness. For quite a long time, gray scale is a headache when LED display's brightness is reduced. BAKO small pitch LED display successfully solves this problem. Even if the brightness is reduced, gray scale is still perfect.
    Photo - http://www.szbako.com/images/small-usa.jpg
    BAKO small pitch LED display has been widely used for TV station, military, monitoring room, etc. With its unique characteristics, it will be more and more popular in many other areas. With eleven years' manufacturing experience, BAKO is sure to be an ideal supplier for you.
    For more information about BAKO:
    Shenzhen BAKO Optoelectronics Co., Ltd
    Tel: +86-755-2999-5896
    Mob: +86-189-3884-0191
    Email: enquiry@szbako.com
    Website: www.szbako.com
    SOURCE Shenzhen BAKO Optoelectronics Co., Ltd
    RELATED LINKS
