NAB: Socionext Develops Small, Low Power 4K/60p HEVC Codec
  • NAB: Socionext Develops Small, Low Power 4K/60p HEVC Codec
    New SC2M50 Designed for a Wide Range of High Image Quality Data Processing Needs for Professional Audio and Video Applications
    SUNNYVALE, Calif., April 11, 2017 /PRNewswire/ -- Socionext Inc., an emerging leader in advanced SoC based video and imaging solutions, today introduced the SC2M50, a new HEVC / H.265 Codec IC. Sample shipments will start in May 2017. Socionext will demonstrate the SC2M50 at the NAB show in Las Vegas, April 24-27, at booth SU13712 in the South Hall's upper level.
    Socionext delivered the world's first 4K/60p HEVC real-time video encoder, the MB86M31 and the HEVC / H.264 / MPEG Multi-format codec MB86M30, for high-end video transmission equipment. Built on the engineering expertise gained from these new products, Socionext has successfully implemented a high-image quality HEVC codec functionality into a small 25mm x 25mm package. The low power device consumes only 3.5W, which allows the IC to be utilized in battery-operated equipment. The SC2M50 supports 4K/60p video and 4:2:2 format, 10-bit input / output, which has excellent color reproducibility, making it suitable to cover a wide range of needs for professional video equipment, including portable devices. Samples come in May, with volume shipping in October 2017.
    Socionext's partners are developing codec devices equipped with the SC2M50. At the NAB show in Las Vegas April 24-27, Socionext will have demonstrations of 4K video encoding and decoding using the latest codec devices. NAB Show: http://www.nabshow.com
    Click here for the SC2M50 Block Diagram
    Main specifications of SC2M50 include the following:
    Video encoding
    HEVC Main, Main10, Format Range Extensions
    (4:2:2 / 4:2:0, 8/10bit, up to 4K 60p)
    Video decoding
    Stream input / output
    TS input x 1
    TS output x 1
    Video input / output
    20bit Parallel I/F input x 4, output x 4
    YUV 4:2:2 10bit up to 4K 60p
    SMPTE-435(Square Division),
    SMPTE ST2036-3 (2-Sample Interleave Division),
    SMPTE 424M (3G-SDI),
    SMPTE 274M, SMPTE 292M (HD-SDI),
    SMPTE 259M-C (SD-SDI)
    Audio input / output
    I2S x 2
    Peripheral interface
    PCI express Gen 2.0 (4 lanes, Max payload size 512 byte)
    USB 2.0 Device x 1
    UART x 4
    I2C x 3
    SPI x 2
    GPIO x 64
    Memory interface
    Serial flash interface HSSPI x 1
    LPDDR4 2400Mbps 16bits x 6 (maximum)
    Image processing
    Video overlay (option)
    Technology
    28nm Process / 1,361 pin FCBGA 25mm x 25mm
    Power Consumption
    3.5W (Typical)
    About Socionext Inc.
    Socionext is a new, innovative enterprise that designs, develops and delivers System-on-Chip products to customers worldwide. The company is focused on imaging, networking, computing and other dynamic technologies that drive today's leading-edge applications. Socionext combines world-class expertise, experience, and an extensive IP portfolio to provide exceptional solutions and ensure a better quality of experience for customers. Founded in 2015, Socionext Inc. is headquartered in Yokohama, and has offices in Japan, Asia, United States and Europe to lead its product development and sales activities. For more information, visit socionextus.com.
    For product information, visit the company's website at http://socionextus.com, e-mail sna_inquiry@us.socionext.com or call 1-844-680-3453. For company news and updates, connect with us on Twitter (https://www.twitter.com/socionextus) and Facebook (https://www.facebook.com/socionextus)
