One intriguing tid bit mentioned in passing in the brief description for the small 4K XPR DLP Home Theater projector the HK2288 is 'programmable 12-bit gamma for RGB'
The HK2288 "brings true UHD-4K resolution, 2,000 ANSI lumens, a 50,000:1 contrast ratio, REC.709 color space for accurate color reproduction, high performance scaling and programmable 12-bit gamma for RGB, and a HDR10 High Dynamic Range to home cinema settings. Additional features include 1.5x wide zoom and vertical lens shift for flexible installation", according to Delta's statement.
On the other end of the spectrum sits the DU9800Z this single DMD Laser-phosphor projector joins the recently announced DPI as the brightest single chipper around. No real surprise as Delta also holds 'a significant stake' in DPI. And DPI says it builds the big NEC DLP projectors, that have a very simillar appearance to certain DPI models. Only the Vivitek version follows ever more quickly.
And for those 4K XPR users requiring a bit more light there is the DK8500Z. According to Delta Electronics it "Achieves true UHD-4K resolution, 7,500 ANSI lumens, a 10,000:1 contrast ratio, embedded edge blending and custom warp, eight optional lens options, and supports 360-degree landscape and portrait mode projection, as well as vertical & horizontal lens shift". Undoubtedly the quoted contrast spec.is achieved by using dynamic black, as in the bigger 9800Z.
The laser cubes now are 4K each, and completely sealed. The newly introduced 4K DLP Laser Video Wall Solution consists of true UHD-4K cubes paired with Delta's DVCS, or Distributive Vision Control System. This platform, which can manage multiple video sources on a single display, enlarge a single video signal to multiple displays or enable centralized control of several video walls, creates an reliable, flexible and scalable display solution capable of fulfilling critical applications, such as surveillance, disaster control and traffic supervision.
It utilizes four industry-leading 4K-resolution laser cubes with 560mm-depth extra slim form factor, features unmatched 4K (3840 x 2160) resolution, and an unmatched 4,000 lumen laser phosphor illumination source, a brightness uniformity greater than 95 percent of its 70-inch cubes. Its built-in Intelli-Sense functions monitor the various parameters of the system and automatically perform real-time adjustments for 24x7 operations. This superior video wall is also the first within the industry to offer IP6X protection rating and an optical sealed engine for up to 100,000 hours of worry-free operation.
