Delta starts selling FE Series HD and 4K LED displays, pitch 1.26mm to 2.5mm
  • Delta starts selling FE Series HD and 4K LED displays, pitch 1.26mm to 2.5mm
    Delta Electronics, known from its Vivitek Display brand and ODM/OEM work starts offering its new FE Series of pre-set size configurations of large format LED monitor solutions in Full-HD and UHD. The FE Series Fine Pitch Indoor LEDs, Delta says: "boasts superb image quality and uniformity, and offers a wide variety of tiles to fit all indoor project requirements. Rugged and robust, the LED wall solution is designed to excel in high ambient light environments, capturing audiences' attention and helping provide an unforgettable experience".
    It also comes with an aluminum die-cast frame that allows for precise installation for perfect alignment. Each LED module attaches magnetically to the cabinet for ease of installation and (front)serviceability.
    Commenting on the introduction of the FE Series, Holger Graeff, General Manager Delta Displays EMEA, said: "The FE Series will accelerate the uptake of LED Narrow Pixel Pitch thanks to the way we now standardize the configuration, installation and maintenance of our 16:9 LED video wall displays. Now, the power of LED technology can be offered easier and faster by any of our AV Partners for use in a wide range of environments, with the reassurance of Delta's know-how in video wall and control room applications for durable and long lasting solutions at low maintenance costs."
    Suited to indoor signage as well as command and control environments, the FE Series offers a modern, sleekly designed large format monitor, offering 1.26, 1.58, 1.9 and 2.5mm pixel pitch, each calibrated to create smooth, consistent brightness and colour throughout the display area. Uniquely, Delta Display Solutions now offers the LED cabinets in pre-determined sizes ranging from 110" to 220" in Full HD, and 220" up to 440" in UHD resolution. The fine-pitch pixels choices and size configurations perfectly accommodate a wide range of viewing distances and applications. Each is in an exact 16.9 aspect ratio – so there is no need to reformat or resize images - which fits standard content supplied via a multitude of sources, as easily as if connecting to a monitor. The individual modules are 27" diagonal.
    Delta says its FE Series of indoor LED Display Systems start from 75.000 EUR, excl. installation. Would that be for the smaller, but finer pitched 110" HD display or the 220" 2.5 mm version? Delta does not say. At this price it basically offers HD resolution Direct View LED where comparable LCD displays offer 4K resolution. An interesting price point reduction for LED. Of course the real cost is in the finer pitches and 4K.
    LED curtains and higher pitched displays are commotized and can be had for low prices. In Europe one local signage company offered a LED curtain for 1500,- euro and up. But these often have a 20 mm pitch, and represent a completely different product from the fine pitched high end video displays.
    The seamless and high resolution display provides wide-viewing angles giving an immersive experience that maximises audience engagement in short viewing distances. Delta's FE Series offers optional ambient light adjustment, emitting a bright and vibrant image no matter what the ambient factors are, such as bright, dark and variable lighting conditions. The FE Series' matched contact points between each tile provide superior accuracy and a seamlessly tight display, while ensuring a solid performance with excellent uniformity, colour and brightness over its lifetime.
    The power supply developed by Delta and optimised for the FE Series supports the level of quality and durability that Delta stands for.
    Delta lists the following Key Features:
    ·        Each individual cabinet has a 16:9 aspect ratio with a 27" diagonal
    ·        Full-HD configurations available in 110", 137", 165" and 220" diagonal
    ·        UHD configurations available in 220", 275", 330" and 440" diagonal
    ·        Cost-effective indoor SMD LED
    ·        A seamless and high-resolution display gives an immersive experience
    ·        Wide viewing angles allow for maximum audience engagement in short viewing distances
    ·        Minimal power consumption: Delta FE is designed with optimised power supplies to minimize power consumption, allowing for a low cost of ownership
    ·        Rugged and lightweight design guarantees reliability
    ·        Delta's uniformity calibration technology provides uniform colours and brightness
    ·        Front installation options and a compact, lightweight design guarantees an easy, quick installation
    ·        The ultimate indoor LED display for image quality assurance, colour uniformity and low cost of ownership
    ·        Certified UL, CB, CE, FCC, CCC
