Delta demonstrates 4K Laser Cubes video wall and Vivitek laser projectors
  • Delta demonstrates 4K Laser Cubes video wall and Vivitek laser projectors
    Delta and Vivitek are showing a new 4K 70" Laser projection cube offering 4000 lumens, and rated lifetime of hundred thousand hours. Other laser cubes and four new Vivitek laser-phosphor projectors.
    Delta's booth features its laser cube based videowall displays. Built around the world's first 4K DLP laser video wall, which boasts brightness up to 4,000 lumens, 33 percent lower power consumption with its eco-friendly laser engines, and an expected lifecycle up to 100,000 hours for its 70-inch cubes. Delta's new distributive vision control system, DVCS 3, is capable of processing 4K images over network and supporting up to 10,000 signal sources and display units, with no signal quality degradation even over long distances.
    The wall at the show consists of an 2x3 array of 70" 4K cubes. Demonstrated use case is 'the industry's first 4K DLP Laser Video Wall for surveillance control rooms'. The ultra slim cube design has a depth of only 22", conserving precious space in tight control rooms. Its laser engines have an lifecycle of up to 100,000 hours (11.4 years) and use 33 percent less power when compared to traditional LED cubes. This video wall also offers industry-leading IP6X anti-dust protection rating and reliable and eco-friendly heat pipe cooling.
    Vivitek, is displaying for the first time its new DK2688, DH678Z, DU4771Z and DU7195Z projectors. These Vivitek projectors create bright, vivid and crisp visuals to engage viewers with projects sized to accommodate classrooms, work spaces, museums, auditoriums and more. To ensure the best cost-of-ownership, each projector has been carefully designed with features that provide long-lasting operation and reduced energy consumption, without sacrificing performance. All new models utilize DLP® DarkChip3™ and BrilliantColor™ technologies to deliver optimal black levels and vibrant colorful images.
    The Vivitek DK2688, a new Ultra HD 4K projector, can display the finest details thanks to 8.3 million pixels projected on the screen, which is four times the FullHD 1080p resolution. Providing a high brightness of 4,000 ANSI lumens, and contrast ratio of 50,000:1 for a worry-free projection in any indoor environment, the DK2688 also features a HDR10 (High Dynamic Range) for precise natural colors. Equipped with a wide 1.39-2.08:1 T.R. lens and vertical lens shift, it provides convenience and flexibility for its installation. The DK2688 is well suited to liven up any business environment in high quality 4K resolution due to its three HDMI v.2.0 input ports.
    The Vivitek DU4771Z WUXGA laser phosphor large-venue projector now offers an impressive brightness of 6,000 ANSI lumens, 20,000:1 contrast ratio and an impressive color saturation. The optical sealed engine enables minimal maintenance with operations up to 20,000 hours for a low total cost of ownership, offering an unbeatable return on investment. The 4-corner adjustment, vertical and horizontal lens shift, as well as a wide 1.65x Zoom lens provides high flexibility to the system integrator for its installation. Digital I/O ports include HDBaseT™, and three HDMI v.1.4 ports, of which one has MHL compatibility.
    The DU7195Z is Vivitek's newest interchangeable lens, large-venue laser phosphor projector with a WUXGA resolution, high brightness of 8,000 ANSI lumens, outstanding 20,000:1 contrast ratio, and the capability to deliver stunningly colorful images and optimal black levels. Equipped with a full suite of I/O ports including HDBaseT™, two HDMI v.1.4 ports (of which one has MHL compatibility), DVI-D, component (BNC) connectors, the Vivitek DU7195Z is also 3D-ready, and allows connection to external transmitters with 3D-Sync-Output port. Distorted and trapezoid image issues are easily corrected with Vertical/Horizontal keystone and 4-corner adjustment. There is a wide choice of 7 optional interchangeable lenses from 0.77:1 to 5.0:1 T.R. for all kinds of installations. Thanks to its solid-state illumination source, the DU7195Z can do 360-degree and portrait mode projection.
