Digital Projection will preview the Satellite Modular Laser System MLS at InfoComm 2019. MLS is a central RGB Laser light source for one or more projection heads, with associated projection heads. Or as DPI describes it as "simple building blocks that will allow users to address a wide range of applications, from single projector installs to complex, multi-channel domes, caves and simulators".
The keystone of this new system is the separation of the light source, with its associated power and thermal management, to a remote location, which enables a small, compact projection 'Head' that only contains the minimal optical and video processing.
The projector 'Head' is fundamentally compact, quiet, light-weight and consumes very little power. This offers huge benefits at every stage of a system design, from transportation and installation to serviceability and lifespan. By separating the projection Head from the light source and linking the two by robust and flexible fibre-optic cables up to 100m long, a bit restrictive in large facilities. Digital Projection's latest innovation offers the installer many more options, particularly where space and access are restricted.
