Genelec to showcase 4420 and 4430 Smart IP loudspeakers at ISE
  • Genelec to showcase 4420 and 4430 Smart IP loudspeakers at ISE
    Growing loudspeaker range gives ‘Power to the speaker. Power to the installer.’
    Genelec - the global leader in professional audio monitoring – is proud to
    be showcasing two Smart IP loudspeaker models at the forthcoming ISE show in Amsterdam. The 4420 and
    4430 loudspeakers combine both exceptional sound quality with single cable convenience, and their
    onboard Smart IP technology provides scalable power, audio and loudspeaker configuration, supervision
    and calibration features via a standard CAT cable. Smart IP therefore offers system designers, integrators
    and installers an easy, powerful and cost-effective solution for guaranteeing enjoyable, high-quality audio
    across entire installations.
    Having been unveiled before a select audience of specially invited Nordic integrators in Helsinki in December,
    the 4430 will be making its ISE debut alongside its new and even more compact 4420 sibling – with yet more
    Smart IP models expected to be added to the family in the future.
    Producing the clarity and intelligibility for which Genelec has become a benchmark, the 4420 and 4430 are
    compatible with both Dante and open IP standards including AES67 and ST2110-30, and derive power via
    PoE and PoE+ Power-over-Ethernet formats. Both models feature a single rear panel CAT connector which
    also allows access to Genelec’s Smart IP Manager - a sophisticated software tool that allows installers to
    configure an almost unlimited number of rooms, zones, loudspeakers and audio channels, and includes
    device discovery, a versatile room equalisation tool set, system organisation and status monitoring. This
    enables installers to deploy Smart IP loudspeakers even on highly complex, acoustically challenging projects.
    While Smart IP Manager is designed specifically for installers to use during set-up and configuration, the
    4420 and 4430 can be integrated easily into house automation systems using a public API command set –
    allowing the end user instant access to volume, power on/off, loudspeaker activity and a selection of preprogrammed audio settings. Smart IP supports uncompressed low-latency audio streaming directly into
    each loudspeaker, with loudspeaker synchronisation to sub-microsecond level for solid acoustic imaging.
    Streams can be managed by both Dante Controller and Dante Domain Manager software, as well as legacy
    balanced line analogue audio. This flexible connectivity allows both IP control of an analogue source, or use
    of analogue audio as a failsafe back-up.
    In terms of technical specification, the 4420 stands just 226 mm tall yet offers a frequency response of 55 Hz
    – 39 kHz (-6 dB) via a 4 inch woofer and 3/4 inch metal dome tweeter, producing a max SPL of 100 dB via
    onboard 50 W Class D amplifiers for each driver. In comparison, the 4430 measures 285 mm in height,
    delivers 45 Hz to 39 kHz (-6 dB) via a 5 inch woofer and 3/4 inch tweeter, and produces a max SPL of 104
    dB via its onboard 50 W Class D stages.
    Manufactured sustainably to offer low power consumption, total reliability and long life, the 4420 and 4430
    enclosures are produced from recycled aluminium, are available in black, white or 120 custom RAL colours,
    and are compatible with Genelec’s extensive range of mounting accessories to allow both models to be
    floor, ceiling, wall or truss mounted.
    Looking ahead to the forthcoming ISE show, Genelec Managing Director Siamak Naghian commented:
    “With the 4430 already being utilised on prestigious Nordic installations - including Helsinki’s Finnish Music
    Hall of Fame, Moesgaard Museum in Aarhus and the new G Livelab music venue in Tampere, we’re confident
    that the new 4420 will also be embraced by installers looking for an even more compact Smart IP
    loudspeaker solution. The overwhelmingly positive feedback that we’ve received from the early adopters of
    Smart IP makes us extremely excited about ISE - and the potential of our AV Installation business in the
    future.”
    Genelec will be showcasing the 4420 and 4430 on Stand 3-B115 of the ISE Show, which takes place in
    Amsterdam between 11th and 14th February. For more information please visit www.genelec.com
