In a football match, there will be a winning team, a team scoring first, a team scoring later, etc. All of these forms are set by bookmakers as betting odds to attract players. One of them is the first goal bet. This is a special type of bet for those who love teams with an attacking style of play. Let's follow the following content to understand this type of bet as well as free late night football tips for playing accurately from the masters!
Introduction to the first goal bet
In football, scoring goals is the main goal of teams when they compete, while also being the factor that brings ecstatic emotions to fans. And to increase the drama and expectation with goals, betting odds such as the first goal bet are always enthusiastically received and chosen by many players. They become side bets that are cared about and attract many players. In fact, many people have won rewards from this type of bet.
Simply put, the first goal bet is when players bet on which team will score the first goal of the match. This is a special type of bet that only appears at reputable bookmakers and has a team of experts offering many different odds. Betting on the team to score first goal often appears in big football matches and is considered by bettors to be simple, easy to play, and easy to win because the odds are 50-50.
Characteristics of the first goal bet
The first goal bet is a side bet that bookmakers often offer alongside other attractive main odds. This is also a type of bet that uses goal statistics as the betting object. Accordingly:
Betting method: choose the team with the ability to score first.
Winning probability: ½ (50%, because there is only 1 of 2 choices)
Determination of win or loss: based on the official result of the match, using the first goal of the match to be recognized.
Winning odds: specific to each team, clearly stated by the bookmaker on the odds board. Reward = bet amount * winning odds (according to European odds).
Characteristics: no need to care about the final result, newcomers can check and choose bets easily.
Rules for calculating results in the first goal bet
In a football match, there will be many special cases. So how do you calculate points?
If a match is canceled before it starts, the bet will be canceled → return the bet amount to the player.
If the match has taken place and there is a goal but has not ended yet for some reason, the first goal will still be counted and the last goal will be canceled.
If an own goal is scored → count the goal for the opposing team.
Only recognized goals are counted: even if the ball has entered the net, if the goal is not allowed due to fouls, offside, etc., the goal will not be allowed.
Find out more information : what is an asian handicap bet
Experience in betting on the first goal accurately without adjustment
The first goal betting is often offered by the leading bookmakers in matches with significant disparities in strength, reputation, or team composition between the two sides. It can also occur between a team with a large number of strong attacking players and a defensively weaker team. Due to its attractive nature and high odds, it attracts a large number of participants. To increase your chances of winning this type of bet, don't overlook the following tips shared by Wintips!
Understand the situation of both teams before the match
This is an effective strategy that every bettor needs to apply if they want to win. Before official matches take place, pay attention to information from forums or bookmakers regarding the main lineups, injuries, personal lives, and controversies surrounding the players. These factors are crucial as they directly influence the form and playing style of the players.
Choose matches where there is a clear disparity between the two teams
This is one of the tips passed down by betting experts for betting on the first goal scored. Choose to participate in matches where there is a clear gap between the strengths of the two teams. By doing so, you can easily determine which team is most likely to score the first goal. Usually, the highest-rated teams are expected to score the first goal. Therefore, players should try this tactic with an appropriate amount of wager to have an enjoyable experience. However, never bet without thoroughly researching the information between the two teams, as it could lead to erroneous predictions and subsequent losses.
Pay attention to the main strikers
Find out if the team you want to bet on has any key strikers because these players are often the ones to score goals. Typically, a team will have 1-3 top scorers. Therefore, researching and paying attention to these players is also an important factor in securing your winning chances. For example, prominent teams like Barcelona, with star player Messi, have scored numerous goals. Additionally, Messi is known for his assists, which help teammates score. Thus, key strikers not only directly score goals but also pave the way for teammates to score.
Observe the playing style of both teams
Each team will have its own playing style, which also influences goal-scoring. Teams with highly rated attacking playstyles have a higher chance of scoring goals, reaching up to 90%. Conversely, teams with defensive counter-attacking styles will find it challenging to score goals. Therefore, carefully consider the playing style of each team when placing bets.
Analyze the betting odds
You can analyze the odds from the bookmakers' odds table. Some betting experts' tips include:
Based on Asian handicap: if the Asian handicap odds of both teams are equal or have a difference of less than 0.05, you can bet on no goals scored.
Based on Asian handicap: if the favorite team's handicap is under 0.25, choose the underdog team to score the first goal, and the favorite team will likely score the last goal.
You can also compare the odds from multiple bookmakers to choose the most suitable betting option.
Set a betting limit
Many people, due to not setting limits on their betting, end up losing all their money and even facing bankruptcy. To avoid this, always set a maximum amount you will win and a limit on the amount you will bet if you lose. This will help ensure financial stability and prevent dire situations every time you want to win or lose.
Betting on the first goal is relatively straightforward with high odds and enticing rewards. If you are new to betting, don't overlook the daily betting tips app shared by Wintips above. Surely, if you master them, winning will not be too difficult for you.
