Next target for acquisition by Samsung?
These microdisplays displays are 12.8mm in length by 9.6mm in width. They are composed of microLEDs with a device size of 2-3 microns. The device pitch is 5µm. The high pixel density results is a microdisplay resolution of more than 5,000ppi. The brightness of the green active matrix microLED microdisplay was found to be over 500,000 cd/m². This is represented as an improvement of over 500-times compared to existing emissive microdisplays. The current yield of microLED pixels achieved on microdisplays made by JBD is reported as in excess of 99.99%.<\q>
Fundamental chip technology to do away with current production complexity in bonding seperate emmision and driver wafers, by working on a single wafer. The key is less in the superfine pitch (2019 target double existing demonstrator to 10000 ppi), and brightness, but in the yield. That could make it a mass market category display.
