While I have a factory HC lens coming from Belgium being assembled but weeks away from arrival I decided to have a little fun and add a DIY iris to my existing Minolta lens. There is a mathematical formula to figure the ideal placement of the iris and a few manual methods one of which involves placing a piece of white paper inside the lens to find the image focal point and observe the internal light scatter. The idea is to let as much white light pass while blocking scattered black light. A 0IRE test pattern will appear larger and different in shape in the lens then a 100IRE pattern. 3 chip DLP further complicates things, light during off state scatters from different directions. The iris does not always have to be cats eye in shape but that is what I decided to work with. Adding an additional iris in the projectors light pipe will add further results. It is important if multiple iris are used they all be the same shape, if not the result could hurt contrast.
I constructed the aperture of very heavy paper stock painted flat black with a layer of felt tape on top.
It will be interesting to compare the size and shape and location of my DIY iris to the factory HC lens once it arrives.
While I did not measure light loss visually I noticed very little loss from the iris compared to the iris placed in the light pipe. Caution: getting to aggresive with the iris aperture will cause uniformity issues.
Below are resulting numbers measured using a Minolta T10. This is a first attempt, I believe there is still room for improvement.
Iris in lens with stock iris in light pipe.
DCI color space
2k lamp
2,415:1 contrast
Iris in lens with stock P iris
DCI color space
2k lamp
2667:1 contrast
Iris in lens with most aggressive iris
DCI color space
2k lamp
3356:1 contrast calibrated
3396:1 contrast un calibrated
I caution everyone I do not recommend this as taking your lens apart could result in canceled warranty and or damage to your lens.
DCI color space
2k lamp
2,415:1 contrast
DCI color space
2k lamp
2667:1 contrast
DCI color space
2k lamp
If it was not for my DP-2K order they would have never stumbled on this one.
Then we order the smaller plates in increments of 5%. We monitored the heat in the light pipe with several of these. The real challenge of increasing contrast is the with lasers.
